Nitrous/injector?
Old 10-23-2005, 11:53 AM
98TA_vert's Avatar
Default Nitrous/injector?
If I'm running a set of LTs,a lunati cam 221/211 .558/.558 114 lsa, stock heads and intake. I want around a 100 shot of nitrous can i go with a dry kit or is that pushing the fuel system to the limit its a 98 so it has 28lbs injectors, if so should i get bigger injectors/fuel pump or a wet kit?
Old 10-23-2005, 11:56 AM
Retired Street Racer
Matt D's Avatar
28s should be fine for a 100 fwhp shot. I upgraded to 42lb SVO injectors, and it still runs good on motor. If you ever plan on going bigger, I would invest in some 30, 37, or 42lbers.
Old 10-23-2005, 07:13 PM
Matt@HSW's Avatar
I would definitely suggest upgrading the fuel pump, since you already have a cam and most of the bolt ons. If at all possible log you injector duty cycle. With a 100 shot you'll be close to or possibly past 80%.
Matt
