What will these mods be worth in the 1/4?
As most of you already know, my last 2 trips to track netted me a stack of 11.DOH timeslips running on the motor... my setup is a 385CI LS1 with a 700R4 and 4.10's... I am getting the following mods done this week... what sort of improvement do you think I will see? My MPH is in the 123-124 range with sixties in the 1.50 range...
Going from a 78MM LSX to a 90MM LSX
Going from a stock ported TB to a 90MM NW
Adding an electric water pump
Removing the power steering pump and going with BMR's short belt kit
Adding a Fast Toys Ram Air
I am hoping to go from 11.0's to 10.8's... I am being too optomistic?
I think that is possible. I gained about 10rwhp going from a 78mm LSX to 90mm LSX. If I was you I'd add the FTRA at the track. make a pass and then put it on to see exactly what gains it gives you. I don't think the EWP and short belt are worth more than half a tenth together.
My best so far is an 11.04... I would be happy with a 10.999 I don't think I will be wrenching at the track, so chances are I will be driving to the track with the FTRA installed...
Thanks for the reply!
awsome setup and times. you've hit ten's on the bottle right?? now you just want to hit that mark N/A?? i think you'll definetly hit high tens... you were already soooo close, i think 10.8 is possible. i'd love to see the new dyno #'s.
