Drilling jets
Drilling jets
Is there a way to figure out what size drill bit you need to drill say a #78 and 44 jets? Are the numbers just the thousands size of the hole? If so then I can covert to drill size using a chart right?
Thanks
Frank
Thanks
Frank
Well, yes the jet sizes are thousanths of an inch, so a #50 jet is .050 of an inch.
But I don't recomend drilling them, pay the couple bucks and buy them. Your tollerance may not be as high as the manufacturers. Plus if you are using NX jets take a look at the tapers they have, and not all are the same, so even if you match the hole size it may not flow as NX designed it to.
Vinny
Vinny
