few odds and ends
few odds and ends
i have a 1992 camaro, i am trying to paint the door handles the shifter(not the **** itself but the metal pipe) and the E-brake(same thing) i have already sanded it down, what else should i do to prep it and what kinda paint... i want a metalic red color... also any type of clear coat or sealer i should use?
If you're looking for a metallic color, check out Duplicolor's Metalcast paint. You can find it in autozone.
http://www.duplicolor.com/products/metalcast.html
If you do use metalcast, make sure you buy the metalcast ground coat. It will make it look a lot better.
