Will ls6 cam fit stock ls1?
Well....will it? Or do i need to replace springs, retainers, etc? Basically can I just do a cam swap? I've head the LS6 cam is good for F/I setups.
So if I buy an LS6 camshaft from the forums here, I won't be able to just swap cams, I need springs, retainers, etc? If so, what do I need? Car is an 02 SS A4
10 Second Fun Car
Check this How to out. Look at the items needed.
http://www.ls1howto.com/index.php?article=23
With that cam you will need pushrods, might as well go ahead and get new retainers and locks, gaskets, new balancer bolt, and springs.
