laptop for hptuners?
Old 10-29-2005, 01:15 AM
00BadassTA's Avatar
Default laptop for hptuners?
I am wondering how fast of a computer will be needed to run hptuners. I dont need anything special it is just going to be used for my car. Thanks for the help in advance.
Old 10-29-2005, 01:47 AM
Full-Force's Avatar
Well any old laptop will upload tunes but trying to log is a different story. I had a Pentium 100mhz laptop that was too slow to log with. I think if you had a Pentium II 300 mhz or better then you would be ok.
Ebay has tons of them for 149 bucks with Pentium II, 6 gig hard drive, 64mb ram, etc.
Old 10-29-2005, 03:04 AM
nrayome98TA's Avatar
straight from HPTuners.com
Minimum Requirements:
Windows 98 or Better
300 mhz PC or Laptop (Minimum)
600 mhz PC or Laptop (Recommended)
64 MB of RAM
40 MB of Disk Space
Native Serial Port or PCMCIA serial adapter
Old 10-29-2005, 03:25 AM
00BadassTA's Avatar
This should help alot.
Thanks for the info.
Old 10-29-2005, 09:46 AM
98A4LS1's Avatar
No problems here using a Toshiba 550 mHz, 192 MB RAM, 5 GB hard drive, Windows XP with HPTuners ver 1.7. I have not tried HPT ver 2.0 yet.
Old 10-29-2005, 01:23 PM
LS1TECH Sponsor
foff667's Avatar
64 MB of RAM
40 MB of Disk Space
2.0 has slightly different requirements now...straight from the new help file
System Requirements
HP Tuners VCM Suite has been designed to work with Microsoft Windows® 98, ME, NT4, 2000, XP or newer.
Minimum
350 MHz CPU
64 Mb RAM
Serial Port* (Version 1 Serial Interface Only)
USB Port (Version 2 USB Interface Only)
Recommended
650 MHz CPU
128 Mb RAM
Microsoft Windows® 2000/XP
*If you are using a Version 1 Serial (RS232) Interface and do not have a native serial port you can use a USB to Serial adapter.
Use only quality USB adapters such as the SocketCom PCMCIA card adapter or Keyspan USB-Serial adapter (part # USA-19HS).
Use of poor quality adapters will result in poor performance, data corruption or Windows "Blue Screen".
