Drive shaft reccomendations please
Went to make some passes tonight and the stock DS said seeya on the 2nd launch. Not like I'm making gobbs of power but it was an aggressive launch on a good prep, on what "would've" been a motor pass. Prolly would've been a new best 60'.....
Motor is making 460/424 NA and has a 100-150 wet hit on top of that.
So what are you guys who've upgraded using? The ACPT is a hair more than I wanna do for this power level. What else is there?
TIA -
TIA -
TIA -
TIA -
Denny's Nitrous Ready ones seem very popular, and have heard nothing but good things about them.
Link:
http://dennysdriveshaft.com/
If you want to order one off the net, then I would check out some of the sponsors.
If yer in a decent city, then I would do some hunting around to some tranny shops etc. They should set you in the right direction. We have a tranny shop here that builds killer driveshafts and T-braked trannys.
Good luck
Good luck
Good luck
Good luck
i got mine built for about $180 if i remember correctly.
Just make sure you measure from u joint to u joint, NOT tip to tip.
