gm part #'s anyone??
I need the part # for the Z06 clutch slave cylinder(throwout bearing/clutch actuator unit), and also # for a 99 pilot bearing.... not sure what year Z06 slave cylinder to use, I guess 03/04 if it'll fit my 99.... and also part #'s for rear end gaskets, left and right side... thanks for the help
check out
GMpartsdirect.com or in this forum at
https://ls1tech.com/forums/general-maintenance-repairs/336981-lt1-lt4-ls1-ls6-f-body-part-numbers.html or
http://www.evlls1.com/gmparts.html
hope this helps
hope this helps
CLUTCH SLAVE CYLINDER
Part #: 12562767
PN is same for '99-'04
CLUTCH PILOT BEARING OR BUSHING
Part #: 14061685
Look up your required rear end gaskets. I've done enough.
Steve
Part #: 12562767
Part #: 14061685
Steve
