throwin code 0420 , need help!
Old 10-30-2005, 06:46 PM
Rollmodel's Avatar
Default throwin code 0420 , need help!
About a month or two ago the service engien light in my 01 ws6 came on, i had it scanned and it threw two codes, one was 0420 and the other 1416, i replaced both air check valves(1416), and the light went off until about a few days ago, i had it scanned again and it threw 0420, what is that code, and what needs to be done, anyone?
Old 10-31-2005, 01:23 AM
JEB Garner's Avatar
DTC P0420 Catalyst System Low Efficiency Bank 1
Old 10-31-2005, 04:14 PM
Rollmodel's Avatar
what does that mean?
Old 10-31-2005, 04:27 PM
robertbartsch's Avatar
Bad 02 sensor(s), bad cat converter or both.
GM is required to replace a bad cat for nada if the mileage is 60K or less. You don;t have any mods; right?
Old 10-31-2005, 04:29 PM
Bo White's Avatar
I was throwing 0430 which is bank 2 so I just had gomer delete it
Old 10-31-2005, 08:26 PM
Rollmodel's Avatar
I have an SLP catback exhaust, would this void the warranty on the cats?
Old 11-01-2005, 02:16 AM
King Nothing's Avatar
if it's stock then no if it's aftermarket than probably, clal you local chevy dealership and by the way the federal emissions warranty is bewtween 2 years or 24k and 8 years or 80k
