Torque Management in A4 C5
Could someone please confirm if the below is sufficient to completly remove Torque Management ?
1: Open your editor, go to Edit>Transmission>Torque Management.
2: Set Abuse Mode Enable False
3: Set Abuse Mode RPM, Abuse Mode TPS and Abuse Mode Speed to 0
4: Click over on Abuse Mode Torque Reduction vs. RPM. Set all values in Normal to 0.
If so , then what about the following :
* Torque Reduction vs. Torque vs. Shift ? Do we need to zero it out ?
* Retard vs. % Torque Reduction ? Again , should we leave it or Zero ?
* Max Torque ? Current value is 350 . Should this be left or bumped up to 639 ?
* Maximum Engine Torque vs. Rpm vs. Gear ?Do we need bump it up to 639 ?
* Max Torque vs. Rpm ? Current values or 639 ?
Any other fields/tables ?
Thanks guys
Thanks guys
