Sponsored by: DashLynx
'69 emblem (for billet grille use) GM Part number is???
Old 10-31-2005, 09:31 PM
todddchi's Avatar
Default '69 emblem (for billet grille use) GM Part number is???
Looking for this part number. Would like to order one online if possible, since I'm placing a gm partsdirect order anyways.
Any help would be appreciated.
Old 11-01-2005, 12:58 AM
jbuerke142's Avatar
which emblem?
Old 11-01-2005, 02:01 AM
NoTicketsPlease's Avatar
See this thread: https://ls1tech.com/forums/showthrea...ight=earnhardt
1970 Chevelle SS grille emblem GM
Code:3977563
I used the above....did not fit that well and I had to fab a bracket an use jb weld to connect it to the grille.
Old 11-02-2005, 02:36 AM
todddchi's Avatar
I wanted a Z/28 one... I ended up ordering this one from GM parts direct.
#3957935. I hope it is the correct one. Checked some eBay auctions and found the PN.
The GM ones are supposed to be more pliable than knock-offs.
I'm mounting mine off center so it doesn't matter as much... was already planning on fabbing a small bracket.
thanks all
Quick Reply: '69 emblem (for billet grille use) GM Part number is???
