Anyone running Full Dish pistons N/A???
Kinda a continuation of my other thread.
Anyone running a N/A application with a full dish piston like a Mahle???
If so, any problems??
Why are you wanting to run a full dish N/A?
Why not run a stock chamber'd head with say a 6cc dish and 2cc for valve relief?
that will give you a ****-ton of P-V clearance, and get you right around 11:1
might keep tabs on this thread too.
even though its talking about boost, its still relates to quench, detonation, etc..
I had the motor built before I knew anything about quench.
I was to run boost sooner than later, but some things have changed $ wise.
Now I have full dish pistons on a motor that will have to run NA for some time. Thinking I should change them out.
I am 11:1 (close to it) with -12cc full dish pistons as it is with these.
38 cc chambers and around 37 cc's dish piston going in my 434 n/a motor. look at the engine masters challenges and notice their affinity for dished pistons and small combustion chambers
I think detonation is a much more regular problem in a boosted engine... thats why I will not go full dish with my turbo setup. I want that quench deck for safety. I am guessing an N/A engine won't be as sensitive. Full dish seems to be the way to go if you're going all-out.
Thinking about the small chamber and a dished piston...a lot of diesels have the entire combustion chamber in the piston... and flat heads!
He is talking about a piston like this
Not like this
