What would it take to build your own meth Inj. Kit??
Any idea what it would take, cost/time to build a custom meth injection setup versus, buying one off the shelf???
TT-TECH Veteran
Well you could just have a pump and a boost referenced regulator a pump, nozzels, and a Micro switch it would take some tunning wth a wide band but it could be done. It would come on at wot and spray more as the presure/boost increases. At least for a FI application. For N/A I would have to put a little more thought into it. Probably would on the FI one also, but that would be a start.
If I had it to do over I wouldve built one since I had to do so much to mine to fix shortcomings. Its not cheap though. I would buy a nice digital progressive controller (not sure which one since I got a progressive controller with my Snow kit) then a nice shurflow pump. I just replaced all my hoses with braided line and aeroquip fittings. You should also get a one way check valve. I would think at least $400 or so for a nice setup.
Here is a link that some GN guys use to make their own Meth/inj. setup. Their are quite a few guys that build their own. hope this helps you out.
http://members.***.net/stevemonroe/AlcoholInjMod.html
