Do you have to reset Computor
Old 11-06-2005, 10:36 PM
Rodman1966's Avatar
Default Do you have to reset Computor
I installed a Callies Stroker 427 Crank giting Code PO 366.
Do I have to rest Computor???????????
Old 11-06-2005, 11:37 PM
WS6FirebirdTA00's Avatar
what is the definition of hte code?
Old 11-07-2005, 01:09 PM
WAHUSKER's Avatar
Are you sure you didn't mean PO 336, Crank Position Sensor? (can't find a 366)
From an Eboggs post on 'the other site'.....
The following conditions may cause this DTC to set:
Poor connections/terminal tension at the sensor.
Crankshaft reluctor wheel damage or improper installation.
The sensor coming in contact with the reluctor wheel.
The engine running out of fuel.
If the crankshaft rotates backwards, this DTC sets. This condition is only with vehicles equipped with a manual transmission. This condition can occur when a vehicle is on an incline and the clutch is released and an engine stall occurs.
