what oil for procharger head unit?
Sorry to say you have to go to ATI and use THERE SPECIAL oil. I don not believe any one has found a substitute for there oil. If your unit is still under warranty it is a must to use theres or it will be void if there is a problem.
As for changing, 1st change @500 miles there after every other 6000miles. I change mine ever time I change the engine oil, while it is up any way.
Yes there is a drain plug its on the bottom, let the car sit for a while before you drain it or take out the dipstick-fill plug 1st, to relieve what little pressure is in the case. The oil comes in pre measured bottles, and it takes one full bottle.
