just lost my 3rd built tranny
Old 11-12-2005, 01:09 AM
transamhate's Avatar
Default just lost my 3rd built tranny
ok...like it says.....i live in Tx if that even matters.....does anyone know a good shop that can make me a tranny that last.....and at this point....it doesnt need to be a biult 4l60e....they dont seem to last no matter how much money i throw at them
Old 11-12-2005, 01:28 AM
Q
Q's Avatar
check your PM's
Old 11-12-2005, 01:39 AM
98boxer's Avatar
Heres my story - click the link. Sorry if its a bit difficult to read my post, but you can read that I got a good, if not great warrenty from gm. Hope this helps, good luck.
https://ls1tech.com/forums/showthrea...ght=gm+trannys
Old 11-12-2005, 06:50 AM
jxaxsxoxn's Avatar
Heres the best piece of advice anyone will give you.
Find out why your transmissions keep failing.
These tranmsissions are controlled by a computer, sensors, etc.
I did a search here on raybestos and somehow ended up reading a bunch of stuff on line pressure, replacing the force motor with a vacuum modulator, why transmissions burn up when the pressure is controlled by the vehicle control module and it's sensors ,etc.
Old 11-12-2005, 09:45 AM
98boxer's Avatar
^^^Thats great advice. I lost my last tranny cause my stock tranny cooler was plugged up allowing my tranny to reach dangerous tempertures and finally went clunk. I would also advice to get a tranny temperture gauge which im planning on installing soon on my vehicle.
Old 11-12-2005, 12:50 PM
LS1Tech Sponsor
hellbents10's Avatar
The 4l60e can be built to take a great amount of punishment. When a shop builds them they can be installed without checking everything, And the thing that made the first one go takes the rest.
Old 11-12-2005, 10:55 PM
ive gotton about 4 pm's from people all saying Rock on is the way to go.....thanks for all the info.....i plan to give Mark a call at Rock on and see if he can help me out
