Stealth box
Stealth box
Just wondering what the pros and cons were for a mdf vs. fiberglass box. I want to do a double setup with a stealth type box on each side, but the only place I can find that makes a passenger side is subthump. Will I be losing any sound quality with a wood box over a fiberglass? Does anyone else make fiberglass passenger side 10" enclosures?
Thanks for any help.
Fiberglass is ALOT lighter then MDF.
To get that stealth setup, since its not a square hole, it really makes sence to go with a fiberglass box.
Good luck and post pics when your done
subthump is the only place that has them, and they probably won't keep making them. I don't like the idea of having 2 subs facing each other as they will push aginst each other. I would just put one good sub in and call it a day. put the some money on making the car faster, because as you do you will start to like speed more than sound.
I've seen several setups with two subs in the back, and I never realized it would be a problem. I already realized that having not facing the hatch would decrease some of the sound quality, but will be bad to put two in the back facing each other from a SQ point of view?
As for mdf vs. fiberglass there isn't a lot of sound difference. A well built mdf box can sound just as good as a fiberlgass box. The main advantage is that fiberglass can conform to the complicated shape of the car better which results in more air space, but typically costs more due to the time and materials. Subthump stealthboxes only weight 7 to 9 lbs each which is comparable in weight to any of the plastic and fiberglass boxes currently available.
also- i have bought two boxes from subthump in the 3 years i have owned my car. they are awesome but he doesnt like responding to my emails when i have a question i'm going fiberglass soon solely based on that my sub is too big for his stealthbox.
you wont notice any difference in SQ between using MDF and FG. FG will be much lighter and will give you the ability to have a larger box thought since you can form it around the body of the car.
