engine setup
engine setup
Ok, I'm trying to do some serious work to a new car when i get it. I want to get some heads & cam package. i'm unsure of the setup for those yet. I was thinking about from afr heads, and maybe a comp cams. I would also use there valve spring as well. then maybe a set of harland shop 1.8 rockers. The fast 90/90 setup. and to feed all that a set of 36 but no more than 52lb fuel injectors. Then to top it off a good old turbo. unsure of which one to use for that though. Also gotta us a k&n filter and a new lid. That would probably be it for the top-end. I then use a set of pacesetter headers or maybe a complete bassani exhaust setup. from there headers to mufflers. any ideas for any of these particular setups that would be much appreciated.
STS turbo and get a head and cam setup that will compliment it. I don't know much about turbo setups so I can't give you the details. But thats a good option to research
