Valve Spring Question
Is there a stronger Valve spring then the PRC springs that will fit in the AFR 225 pocket? I have a 427 with a 25x/26x 64x/64x 113 cam that is getting valve float. I am loking for something that is rated to 700 lift or higher. I know that the Patriot Golds, Comp 921, and the new AFR 8019 springs are all close to the PRC springs. It is debatable whicn one of those are stronger but they are all close to each other in specs. I am looking for something stronger then all of them.
