Were to secure the engine for removal?
Old 11-18-2005, 02:46 PM
LS1FIRE's Avatar
Default Were to secure the engine for removal?
Hello i am curious to know were can I bolt the chain onto my engine to secure it to remove it from the top with the heads off the car, and to replace it? A freind suggested I bolt them down to the head bolt area but I am afraid that it might damage the threads thanks.
Old 11-18-2005, 03:51 PM
Moderator
davered00ss's Avatar
Bolt holes on the front & back of the block.
Old 11-18-2005, 05:37 PM
LS1FIRE's Avatar
Are these the head bolt holes?
Old 11-18-2005, 05:53 PM
91sbcamaro's Avatar
i used the accesories bolts, i just took out the accesories and put the bolt back into hte hole with the chain attached, also there is the same type holes in the back of the block also.
Old 11-18-2005, 06:38 PM
67Ranger's Avatar
you can do it like that, or you could possibly use two head bolt holes that are across from eachother on the top, and pick it up like that.
Old 02-09-2006, 02:12 AM
LS1FIRE's Avatar
any other good loactions to secure them at?
