what happens if
what happens if
the noids stick open for some reason, and why would they stick open.
i wanted to go wet but then i herd of puddeling and blowing the IM off.
does dry do that?
im 19 and i want to spray a 100 shot but the dry Vs. wet is driving me crazy
one thing i like about the wet is that i dosent relie(sp) on the injectors.
but then the dry dosent puddel.
just try to help plese....
does dry do that?
if you truely intend to only spay a 100 shot then I would recommend a basic dry kit with all the neccessary safety stuff like a fuel pressure safety switch, WOT switch/window switch and you should be fine.
