Need Help With Clutch Master Cylinder!!!
well the master cylinder is going out in my 99 camaro ss, i need help on how to install it and any diagrams would help thanx
LS1TECH Sponsor
Check out www.installuniversity.com There is a good write up on that site. The worst part of the install is getting the U bolt through the firewall. After that is is the clip on the clutch peddal.
Just did mine last night actually. Make sure you put the U bolt on the master before you try and put it back on. Also be sure you've got a buddy inside the car to guide the rod where it needs to go. It really wasn't that bad it took us about 20 minutes to get it back in and hooked up.
