Anyone else not notice much MPH gain with headers?
Old 11-23-2005, 01:52 PM
ConfusedGarage's Avatar
Default Anyone else not notice much MPH gain with headers?
I only gained about 1 mph with SLP headers and Y pipe wcats on another car. Anyone else have the same thing happen, or better gains?
The et went down 2 tengths though.
Old 11-23-2005, 01:57 PM
BlackHawk T/A's Avatar
Sounds like you could use a tune.
Old 11-23-2005, 02:10 PM
krexken's Avatar
Don't forget about air quality when you made those passes. Weather alone can make several tenths/mph difference.
Old 11-23-2005, 02:22 PM
Similar conditions when I went.
Car was an A4 02 z28 (3.23 rear)
went 13.28 @106 stock w/lid
went 12.98 @110 catback
went 12.73 @111.xx headers
went 12.52 @111 on nittos.
Put down 323/320 on the dyno...although those seem real low. Maybe it was the tune.
Im gonna try and find a very mild cam and retune the car that way.
Old 11-23-2005, 05:29 PM
radz282003's Avatar
I' ve gone 107 with a 'verter, with a good tune. I have dynod 20 more RWHP, with LTs and a stall ( locked ), than with MACs and a stock verter. I would expect you should gain a good 2-3 tenths, and a a MHP or two, if you could hook up. With my stall and LTs, I can' t floor it until after the 60' on stock tires.
I suggest a tune, and I' m sure you will find some good gains
Old 11-23-2005, 05:54 PM
SUX2BU's Avatar
SLP's are the bottom of the totum pole when it comes to headers.
Old 11-25-2005, 11:14 AM
WILWAXU's Avatar
What he said.
There's more to weather than Temperture. Namely air pressure or Baro. If you don't track the weather closely, you can see drastically different results on a naturally aspirated car.
Old 11-25-2005, 03:26 PM
dannyz's Avatar
Am I reading this right? You picked up 3 tenth's with just a cat back?
Old 11-25-2005, 04:08 PM
Lane's Avatar
If I remember right, each tenth equals about 10 rwhp - which means you picked up about 20rwhp. Sounds pretty good to me, considering you kept cats on the car.
With headers and my duals, I usually saw a pickup of around 30 rwhp on average. Over stock manifolds and stock Y.
