Causes of "Real" Knock?
Old 11-28-2005, 02:06 PM
schultzsj's Avatar
Question Causes of "Real" Knock?
I have posted and searched my knock retard problem (timing is about 17 degrees due to -4 KR and -10 low octane table). I think that it is probably false and so I am preparing to address possible sources of false knock but I need to look at possible sources of real knock as well (even though I cannot hear it).
Real knock can be caused by:
1) Bad/low octane gas (unlikely since the KR is present all the time).
2) PCV oil (there was no significant oil in my intake but I noticed that my PCV line was unhooked at the valve cover when I did my cam, it us hooked up now so I am going to install a catch can).
3) Carbon deposits (is it worth doing SeaFoam just in case - this does not seem like it would be good for the engine).
Anything else I can look at that could be causing real knock?
Thanks,
Steve
Old 11-28-2005, 02:23 PM
LS1Tech Sponsor
hellbents10's Avatar
Run some SeaFoam in there. Also it never hurts to put some 100 octane in there to see if the knock is false or not.
Old 11-28-2005, 05:15 PM
10 Second Fun Car
jlrz28's Avatar
Bad knock sensor?
Old 11-28-2005, 05:18 PM
MadBill's Avatar
Yes, high octane is a great test! We had a knock problem once that 100 UL didn't touch; turned out a sparkplug was loose from the factory and overheated so much it turned into a glow plug! (Too high a heat range is the same issue.)
Other causes of 'real knock':
o- Overtorqued/oversensitive sensors reacting to trace levels.
o- Lean cylinder/cylinders due to restricted flow injectors.
o- Air pockets or other causes of localized overheating.
False knock:
o- Valve noise, piston slap, exhaust system grounding out under load. (One band aid fix is to under-torque sensors or wrap threads in teflon tape to reduce sensitivity.)
o- Defective knock sensor.
o- I'm sure there's more...
Old 11-29-2005, 02:14 PM
schultzsj's Avatar
Thanks for the replies. I will probably work on most of the suggestions except maybe not the sensors themselves yet - I am getting no codes and I don't want to pull the intake if I can help it.
I just installed a 227/224 cam and found out about the KR during the tune. I don't know if it was there before the cam or not but, if not, it may explain the less-than-expected performance improvement (about 0.1 sec & 1 mph in the quarter and 361 HP on the dyno).
Where do I get SeaFoam?
Thanks,
Steve
