Rearend ???
Rearend ???
I am wondering what is the most compon part on the GM 10 bolt that breaks because i would like to try and avoid replacing my whole rear because i am tight on money i am hopeing to get away w/ possibly getting a new better posi or something any input would b great thanks
Is it a M6 or A4 to start. If it is a A4 you will be ok for a while depending on your horse power. M6 you will break the axles or the spiders and possible the case. If it is a M6 time to step up to a heavy duty rear. Hope that helps.
