What TC's to use for TH350 & LS1?
Restricted User
Is there a special LS1 TH350 TC, or will any TH350 TC work? I may need a short term limper to get me by if I need to send my ATI in for repair, dont want to break the bank doing it though. Thanks
Charlie
Charlie
Originally Posted by SUX2BU
as long as your flexplate has holes for an old school converter to bolt up you can use any converter. the nose won't go into the crank but mine doesn't anyways. no problems here.
I have seen converters come out of the car and it will cut the car in half and even hurt people when installed like that.
You have a time bomb !!! the flexplate will not contain the converter by itself ,and you will also loose your front pump on the trans even if it stays in place by some chance
