F11 or F13 cam?
Old 12-11-2005, 08:09 PM
jlashley2001ss's Avatar
Default F11 or F13 cam?
With my mods in sig. which of the cams F11 or F13 would suit my car the best? Its a daily driver so take that into consideration. Also im thinking of just going the comp 918 valve springs. Are these springs good enough?
Second what LSA should i go with 112 or 114? Thanks In Advance guys!!!
Old 12-11-2005, 09:59 PM
AFTICA's Avatar
Just went thru this with Allan from Futral.Same situation, same 918 springs For me the deciding factor was the shift points. I limited the shift points to 6500. Based on that Allan recommended the F11 on a 113+3. He said to get the most out of the F13 you need to shift it at 6700 - 6800 and I wasn't willing to go that high.
