Shims & head gaskets
My pistons are coming out of the block .015" (block was decked) so I now need to get thicker gaskets.
While looking for thicker head gasket choices, I noticed several of the big head gasket companies offer stainless steel shims (.015, .010...) Are these used instead of head gaskets, or are they used with the head gasket?
They're fairly inexpensive,like $7.50 for the felpro shims. If these could be used in addition to the head gasket, then I could keep my existing .040" cometics and get a set of .015 shims for $15.
Head Gaskets
Just Rin The Cometic #c5317-051, This Is A Killer Gasket And Still Gives You .036 Give Or Take A .001 Of Piston To Head Clearance. You Still Will Get Plenty Of Squench With This Set.
