What cam is this?
What cam is this?
Hey guys, just wondering if anyone knew what cam this was or who car this is? It's on LS1sounds.com, it's the third one down from the top under the camshaft section. http://www.ls1sounds.com/Borla/borla...lsa_00WS6.mpeg. All it says about the cam is .570 lift with 106lsa. I just wanna see some specs on it.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Grand Am Cup cam. SDPC carries it.
specs:
SDPC Part Number: 88958606
Manufacturer: GM Performance Parts
Advertised Duration Int. : 294
Advertised Duration Exh. : 306
Duration @ 0.050" (I/E) : 239 / 251
Lift (I/E) : 0.570 / 0.570
Lobe Separation : 106
RPM Range : 4000-7000
Cam Type : Hydraulic Roller
specs:
Thanks bud, I appreciate it.
One more thing, I've been looking at the T-Rex Killer cam and I saw this sound clip under the Corsa section of LS1sounds and it just said Joe Overton monster cam and I figured that's what this cam was but wasn't for sure? http://www.ls1sounds.com/Corsa/corsa...am_CamnZ_1.avi & http://www.ls1sounds.com/Corsa/corsa...am_CamnZ_2.avi.
Yea, I've been doing some research and would like to get something right around this size. I started by looking at the T-Rex but then did some research and I'm leaning toward the Killer over the Rex but I also like this Cup Cam too. Looks like you got a pretty nasty cam there yourself.
