I just bought an LQ9 block?
I was wondering what parts were interchangable on the lq9 block with the other lsx motors? Can an ls6 oil pump work on it? Does anyone know what parts are interchangable? I plan on boosting this motor to. any info will help.
If it is an 01'+ block then everything is interchangable. If your putting it into a f body then a whole needs to be drilled and tapped to mount the alternator bracket. Other than that everything bolts right up.
