98 a4 ls1 corvette question...
Restricted User
There is a plug on the side of the tranny pan. To check you need to have the car running and then the plug needs to be removed. If there is fluid coming out the hole then there is enough fluid in it, if not then you need to add enough Dexron/MerconIII until it starts to come out the hole.
