Raised my base spark, now idle goes way up?
Old 12-19-2005, 10:29 AM
Blown Interceptor's Avatar
Default Raised my base spark, now idle goes way up?
I raised my base spark timing in park and drive tables to try get rid of bucking. I never touched this table after installing my TR224/224. I got rid of it, but now when I first start the car when cold, the idle shoots right up to 1500 and stays there for a good 5 seconds.
Did I ad too much timnig?
Thanks,
Jason
Old 12-19-2005, 11:08 AM
Bink's Avatar
What did you raise it to??
You can pull the start up RPM down by making the "Idle Flare Control" more aggressive at 900 and 1000 RPM ( say, -25* to - 30*). Also you could reduce the "Start Up Airflow Correction" value. Both should help.
Old 12-19-2005, 12:29 PM
I am not looking at the file right now, but I think I set the first four or five columns at 22*. I will screen shot it when I get home from work.
Thanks,
Old 12-19-2005, 09:05 PM
Here is the base spark in drive, its the same in park as well.
When you talk about Idle flare control...should I raise it to -25 and go from there?
Thanks for the help!
Jason
