Ls1 engine question..
Old 12-19-2005, 02:21 PM
VenomInside's Avatar
Default Ls1 engine question..
I have found a higher milage Z28 Ls1. I want to mod it. What would i need to do to make the engine better [and not a higher milage break one part at a time motor]
Hope this makes sense.
Thanks in advance.
Old 12-19-2005, 02:23 PM
Ace$nyper's Avatar
Huh?
What do you want to do?
Old 12-19-2005, 03:16 PM
Originally Posted by Ace$nyper
Huh?
sorry i got lost in my own question.. I was worried about modding a high milage car.. Is there anything I can do so that stuff does not start going [since the motor is getting up in the xxx,xxx range.
Old 12-19-2005, 06:49 PM
SAM98WS6's Avatar
First you want to do compression/Leakdown test...might need piston rings.
just like any other motor...new bearings will make it like new...the pistons/rods/crank arent going to wear out.
I would change valvesprings/rockers/pushods/lifters while its apart..as well as the oil pump.
All the little stuff needs to be watched..injectors, fuel pump etc.
LS1s are just like any other motor.
Old 12-19-2005, 07:00 PM
Ace$nyper's Avatar
It's ok happens to us all. Me more so then most
As stated give it a leakdown test. Inspect test things like pumps injectors plugs wires all that.
Myself with a higher mileage LS1 car i'd more worry about rear then the motor.
Old 12-20-2005, 12:39 AM
nice, thanks for the help
