Problem after Problem after LT Install
Hey guys I posted a thread about 2 weeks ago saying that i had problems with major codes and Loud *** Backfiring? these r some of the problems that i have run into and parts that i have bought to "fix" the problems but it seems like when i buy one part to fix it it backfires gets louder and pisses me off more and more, first of all we have a OBII scanner to tell us exactly where the problems r at, first it was a cylinder 4 misfire, checked all the plugs and tested the plugs and everything, that problem goes away for a while then the evapae Solinoid fucked up so i buy a brand new one thinking it would fix my backfiring problem, NOPE. the codes does go away for a while 2 but it still backfired, then i bought the o2 extenders because the scanner was showing a problem with Bank 1 so we install those, Problems r still there and the previous codes for evape and cyclyder 4 misfire show up again, and now the scanner shows that my Map sensor is fucked up and not reading right or i have a vacuum leak , Help me out Fellas Plz
Yep, all of this madness happened after i installed the LT Headers and True Duals, i can drive the car but it pisses me off so much that i would rather not, Thank god I Have a 01 ACcord EX to drive around the thing that bothers me the most is the very loud constant Backfiring, on the go and at full stop , it has been sitting for 2 weeks because i cant fix the problems, o the Check engine, ASR OFF , AND ABS INOP lights r also showing now i need help guys
Originally Posted by Kiss_My_99SS
Are sure you have your O2 wires hooked up right? I've seen people hook them up wrong and that will make the car backfire and throw codes.
