switch my ORY?
switch my ORY?
I recently bought Pace Setter LTs and ORY. After doing more research, I realized that the PS ORY isn't the best. How much of a gain would I see if I switched to the TSP ORY or another brand (no custom setups)? True Duals are out of the question because they are too loud. Thanks for the advice.
Location: Live Oak, FL - in the woods where the creatures lurk.
I don't know about yours, but after reading some posts
I pulled mine back off and took a good look at the merge
point and saw that whoever fabbed it did not bother to
try a matched fit, leaving excess (pipe) material partially
blocking the other pipe.
I used a die grinder to remove most of the excess.
Other than that I have no problems with it.
(pacesetter ORY)
(pacesetter ORY)
!LS1 11 Second Club
Mufflex/QTP ORY will show gains due to its scavenger merge collector. A little pricey, a little hard to get it to fit well, but if you're going to swap y for y, it's worth a look.
