What Fuel Filter with a Supercharger?
I was just wondering if any of you guys were running any kind of special fuel filter with yalls supercharger or Tubo setup...If so what brand and what kind of special connections are needed...TIA
I have a D1SC/60lb injectors on the way & plan to run a stock type replacement filter from NAPA or Autozone. I'll pull the fuel tank & clean it as part of the Racetronix pump install so I shouldn't have any dirt in the system anyways. I doubt anything more is needed when using the stock fuel lines.
