"Normal" MAP reading for big CI?
My stocker is 30kpa.
Whats your idle speed?
That cam is pretty munchy, you might be getting reversion etc. IMHO you should have the same MAP reading as a stock displacement using the same cam maybe someone with a similar cam can chime in.
LS1Tech Sponsor
He should pull more vacume then a smaller motor with the same cam. That being said that about 10in hg of vacume, which sounds about right for that cam in a smaller motor such as a 346. I am betting that with a little more timing at idle you can get a lower KPA number and have a better idle.
With 27* of overlap there could be some reversion maybe. I am running 22* of timing at idle. I could play with that and see if it changes anything.
The car is like a switch...it feels pretty goofy below 2200 rpm but at about 2400rpm it just a monster till redline. Running SD, idle is good, cold start, hot start, etc... settles into a nice idle after about 5 seconds on a cold start and immediately on a hot start. IACs are 35, STITs are about .1, everything is really good. This cam just doesn't like low rpms even on a stroker. I may need to step up to 3.91s as I am running 3.46s now.
I am getting a harrop hurricane manifold here shortly so that will inevitably change the equation...
