Oil pick up tube
Old 01-01-2006, 08:11 PM
CammedTA's Avatar
Unhappy Oil pick up tube
Ok Im trying to get the bolt to the oil pickup tube to go into the oil pump, with the oil pan still half *** on the car. There is no way I can get a tool on the bolt head and I keep droping it in the oil pan. Does anybody think it would be alright if I put some kind of sticky grease on the tip of bolt so it would stick the hole, as Im trying to thread it in. I just want to know if any kind grease inside the oil pan would be harmful to the motor? Or if anybody has any tips or tricks for getting the oil pickup bolt in. Thanks
Old 01-01-2006, 08:12 PM
CBX
CBX's Avatar
Why not just use some assembly lube?
Old 01-01-2006, 08:32 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Just got to take your time. I know it sucks...but its possible. Just got to keep trying till you get it.
Old 01-01-2006, 09:07 PM
REDWS6ROCKET's Avatar
use a 10mm ratcheting wrench. put the bolt in the wrench and you can usually get it started like that. make sure you have a rag in there in case you drop the bolt.
