Comp 918 retainer question
someone said that they talked to comp and comp said the there is slack with the stock retainers and 918's. Im swapping tomorrow. I just bought 918's and new 918's retainers. For $40 I think its worth it to be safe
Originally Posted by Okie5.3
i called comp about using the stock retainers with the 918s when doing the cam swap just to make sure there were no potential issues. comp indicated the stock retainer fitment wasn't as good as the comp retainers and suggested i use their retainer. i looked at as cheap insurance. when doing a side-by-side fitment comparision, the stock retainers had a lot of slop IMO, whereas the comps fit fairly precise with little lateral movement.
I was unable to budge the retainer installed and much less compressed.
the only way I would change those is if I spun over 6300 rpm and I would swap them for titaniums.
Stockers work just fine. (Nothing scary there).
Originally Posted by PREDATOR-Z
Did you do that comparison with the retainer locked and installed?
Comp Cams makes 2 styles of retainer for the 918 spring. Steel and Titanium. He got the steel set.
Per Thunder Racing's web site the Titanium Retainers for 918 springs are $272.99.
