ls1 oil pans
Originally Posted by j-dubya
is there any difference between late model small blocks and the ls1?
Corvette vs F-body: http://www.hpsalvage.com/Oilpan.html
close, for the bottom anyways. i need to cut into it horizontally from the front to make room for the front axle tube. not a whole lot, but i need to be able to do so. and im trying to keep from going dry sump. just a simple stock style steel pan is what i need. by the time im done with it it will look like those posted above.
jeremy
jeremy
