Is it worth building up the factory 10 bolt or better off to buy a 12bolt?
I ask this because I have seen many cars from GNX to F-bodys with built 10 bolts running the quarter in 9s and 10s. Then I have heard many people comment that 10bolts are weak and break, so they are not worth building up or not??
My experience is:
94 z28 a4, while the car was stock I broke the spider gears in the rearend at about 80,xxx miles. Drove hard, no track use
Now
I have 01 z28 m6, built a little (dynoed 347/356 hp/tq) with 90,xxx miles and the rearend is fine with the occasional chatter which its done for the last 60,000miles.
This car is driven hard as a daily driver and raced often. I never race slicks, just street tires or street drags.
My initial thought is: since I’m only building up to about 500rwhp for now a built 10bolt should be fine. I will replace the axles, girdle, ring/pinion(3.42 to 3.73) and posi unit along with a master install kit.
Has anyone else done this and what has your experience been with a car producing 350 to 500rwhp?
In a couple of years if I rebuild the engine and do a turbo install, and up the hp to 800+rwhp then I will install a 12 bolt, but for now I cant see spending the $$$ for it.
So is this a good idea or what?
My experience is:
Now
If your gonna go to 500hp or even close to that with an M6 you will need at least a 12 bolt. Some people have blown the 10 bolt on little more than factory power behind an M6. Also if you try to build the 10 bolt you'd be better off to keep the factory gears. The taller the gear you go the easier it is to break things. And if you are gonna make 800+rwhp, which is a lofty goal, I think you will need more than a 12 bolt. More like a 9". These of course are just my opinions.
I agree with your opinions completely, once I go for 800+rwhp I will definitely got to a 12 or 9.
It is true the factory 10 does blow out on stock fbodys.
But for now with all the 10bolts I see running 9s and 10s in the quarter it leads me to think that building up the 10 is safe.
Originally Posted by TopFlite
I'll be building my 10 bolt and "attempting" to keep it together. A new Tq arm and trailing arms/ panhard rod does a world of good for the weak 10 bolt.
I have seen stock powered 10 bolt cars break the weak S10/Monza derived rear. The automatic cars are easier on them, but the stick cars are brutal on them. I don't advise wasting any money on trying to build the 10 bolt, as every part is small, and the next weakest link then breaks. This rear is much smaller than the 10 bolts used in the G Body's back in the 80's. Bob
As others have mentioned if you do research on cars running really any faster than 12.0's as far as I can tell on a 10 bolt rear are all A4s. The best argument I've ever heard for getting rid of a 10 bolt was a guy on here who broke his at the track at like 55 or 60mph and the rear locked up on him at that speed. I don't care to ever have that happen to me.
that makes sense. The majority of the 9 sec and 10 sec 1/4 miles cars that I have seen running a built 10 bolt is automatic GNX.
I didnt realize the M6 was that brutal on 10bolts and I didnt know that the 80s 10bolts where bigger.
That answers alot and thanks too!
When I received my 12-bolt and the stocker was pulled from my car, I put them side by side and the stocker looked like a sad little toy in comparison. It's really no wonder these grenade on people pushing the power these cars are capable of.
all though my car is a a4. i have 530 rwhp, ran 11.7 so far.
no problems with the rear. i am planning on doing high 10's in the spring.
with the stock rear 3.23's
dont replace it if its not broken.
