Drag Sway Bar Question
In the picture below, does the triangular bar pivot at the area that is circled or is it welded solid?
Is their a bushing in that area?
Sorry if this is a stupid question, I searched without any results.
Thanks in advance,
Dave
Thanks in advance,
Dave
It should pivot.If you disconnect the links on both sides pass/driver the arm should rotate freely. With Driver seated in car I connect the driverside arm and then get the bolt to freely pass thru on the pass side .Then add preload of 1/8 th turn
