Crack in Dash...help
Hey guys i was wondering if there is anyway to fix this crack thats in my dash..its maybe 4 in long. but no longer then that..if anyone can help i would appreciate it alot..thanks
Its fairly common to find that dash panel on ebay pretty cheap . Like under a 100 bux . IMO its not worth fixing . You could use a ABS plastic adhesive ( Oatey is good brand ) and it would bond it back together , and be be quite strong . But the crack line would still be there . Youd have to fill the crack with plastic filler , then paint with color matched vinyl dye .
Id just buy another one . You can use one from a 97-99 for the correct color , the firebird panel will work too as it is the same as the camaro . The 93-96 firebird panel looks like will work , but it will not . There is one line where it contours the dash that is totally different .
Hope that helps .
Hope that helps .
I just had to buy another one as well. Put a crack in it and decided i would take it out and try to fix it.
Well, short story is I tried to remove it to fix it, and it ended up shattering into like 10 parts. I was bummed and had to buy another.
Good luck with yours.
