Replacing valve cover gaskets
I need to replace my valve cover gaskets on my 1999 F-body. To do so on the drivers side , am i going to need to disconnect the fuel lines to the Rails or should i be able to get them off without a problem ?
Originally Posted by 777
I would recomend taking the coil packs off for sure. I have done it before without taking the coil packs off but it was a pain in the butt trying to get them back in without the gasket messing up.
Is there ne order the bolts need to be tightened and what are the torque specs for the bolts
