Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Vortec CSFI Metering Body and Poppet Valves
Old 01-12-2006, 09:12 PM
fastta's Avatar
Default Vortec CSFI Metering Body and Poppet Valves
I'm replacing my CSFI metering body, poppet valves, and hoses this weekend on my 5.7 Vortec in my 1998 Tahoe, and I was wondering if anyone here has done this? Any tips and/or advice would be appreciated. I have worked on motors most of my life, but just never a Gen 1 Vortec. Also replacing the fuel pump as well.
It seems to be a pretty easy and straightforward R&R, but it never hurts to ask.
Old 01-13-2006, 08:19 PM
fastta's Avatar
Anyone here with any Gen 1 Vortec experience?
Old 01-14-2006, 02:26 PM
FastRedChevy's Avatar
Pretty easy just get the plenum off and replace the whole spider unit.
FYI there is a upgrade for the injectors that are far better than the stock one. They are avalibe from GM
Check out fullsizechevy.com there are many there that have done this.
Old 01-14-2006, 03:22 PM
fastta's Avatar
Thanks, it seemed like an easy R&R, but it never hurts to ask. Thanks for the link.
Old 01-14-2006, 08:01 PM
SSilverado408's Avatar
The upper intake is fairly easy to remove. You may need a special GM fuel line disconnect tool to remove the fuel lines fron the sender.
Old 01-14-2006, 11:25 PM
fastta's Avatar
Yeah, basically that's what I was getting at was whether the poppet valves could be removed by just removing the upper(plastic) plenum. So i guess yes. I already have all the fuel disconnect tools, but thanks.
I'm going to remove and clean the EGR as well.
Quick Reply: Vortec CSFI Metering Body and Poppet Valves
