What solid roller do you use?
Old 01-13-2006, 10:46 AM
DavidNJ's Avatar
Default What solid roller do you use?
While the various tuners all offer off the shelf hydraulic cams using lobes from Comp, Crane, Cam Motion, and others, they don't offer off the shelf LS1 solid cams.
So if you are running solid cam, could you tell us:
  1. What lobe profile you use?
  2. What are the durations, lsa, and advance?
  3. What rockers you use?
  4. What valve spring you use (optionally with installed height)?
  5. What is your basic engine configuration?
  6. How you use it (daily driver, road racing, drag racing, combination)?
  7. Have there been any problems?
  8. And how satisfied you are with it?
For example you might say: 'A Comp Xtreme Street Roller, 230/236 114/+4, with T&D 1.7 shaft rockers, comp 26112 spring, on a 346 with AFR 205 heads and Fast 90 intake. Used for commuting, track days, and an occasional drag racing day. No real problems and it runs fine.'
Thanks,
David
For example
Old 01-13-2006, 08:12 PM
MadBill's Avatar
I guess I have to say something here like: "I'm all ears on this too!" in order to have the option of receiving instant e-mails re any posts?
Old 01-14-2006, 12:00 AM
DavidNJ's Avatar
To the top
