Going to the track tonite, first time in RWD
ok so im going to the track tonite, i know all about the tree and stuff *i used to drag a volvo*
so i am new to RWD and i know about brake boosting *its auto*, wondering what RPM to launch at and what PSI to set my tires at *275/40/17s* BF Goodrich Comp TAs
well with street tires, you should leave the psi at the normal level because of the hard sidewalls. When launching, I find it best to just stall it up to 800-1000 rpms, any higher than that and you'll probably start to spin the tires. When the light turns green, I press the gas down only 3/4 of the way and then immediately go WOT. I was able to get the 1.99 60' with my crappy 245/50/16 all season tires, so hopefully those tires you got will help you a lot.
I've noticed that you already went last night, so how did you end up doing?
