STS turbo hanging low to ground
Old 01-14-2006, 04:46 PM
LastBlack02SS's Avatar
Default STS turbo hanging low to ground
So we are almost done doing the install. The only problem is the turbo is hanging maybe 2 inches from the ground. Any suggestions?
Old 01-14-2006, 06:37 PM
trtturbo's Avatar
ITs all in how you mount it. If you havent already welded the pipe, loosen both housings and rotate them and the mounting pipe up as far as it will go.
This may cause issues using the STS exhaust pipe as the tailpipe may hit the exhaust pipe. I would rather alter the pipe and have the turbo high.
Old 01-14-2006, 07:46 PM
Thanks. I'll give that a try. Also we just ran into the pipe that mounts to the K-Member bolt not matching up to the bolt. It is off by a few mm. We tried losening other pipes and I guess will just have to do that all of the way back. Any other suggestions or similar occurances?
Old 01-14-2006, 09:03 PM
Blackbird's Avatar
You installing it down in Morgan Hill or up there? If down here I told Marcin to give me a call and I can come give you guys some pointers if you like.
Old 01-15-2006, 06:02 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=32
We added a hangar to keep the turbo up higher, you can check it out above. Bob
Old 01-26-2006, 07:42 AM
98Ztwentyeight's Avatar
i used his hangar idea. i just added a stud and 2 nuts, 2 washers and 2
wearable fiber discs to my turbo and bought a normal exhaust hanger from
Oreilly's auto parts.
and my turbo is a 1/2" from the sheild on the turbo assemblies highest point
the oil check vavle fittings. and the turbo still has a little freeplay to move
incase i hit some rough roads.
heres my cheesy diagram
I
I
------ } [ I I I [ }
stud into turbo then a nut to hold thehousing, then astainless washer then a wearable fiber washer then hanger then a wearable washer then a stanliss washer and followed buy a locking nut tighted up just a little
it makes no added noise and my turbos up where it belongs
Quick Reply: STS turbo hanging low to ground
