converting ls1 intake to fast intake????
Old 01-14-2006, 08:10 PM
konryod215's Avatar
Default converting ls1 intake to fast intake????
have a 98 T/A do i need the coolant pipes from a ls6?
Old 01-14-2006, 08:44 PM
Nick D's Avatar
Yes, you will need the front coolant pipe, 2 rear coolant plugs, I would suggest a new tb gasket if changing that as well. The FAST I bought didn't come with bolts for the TB and if you break the oil pressure sending unit like I did, then you will need a new one (from AutoZone like $40) and a oil pressure sending unit socket (~$4). Aside from that, just all the tools you can find and expect a lot of scratches from the cowl. I looked like I got attacked by a cat after I was done.
Old 01-15-2006, 02:29 AM
konryod215's Avatar
so the front just gets the pipe and the back one get pluged up right?
and how much are they? and where can i get them?
Old 01-15-2006, 02:46 AM
TA TECH's Avatar
I got mine from tsp yep the front is a pine and the rears are just plugs! On my 90 fast I had to bend the front pipe so the intake would go down to seal!I think I give around 40ish for the set!
Old 01-15-2006, 07:04 PM
konryod215's Avatar
TA TECH could u send some pics to konryod@hotmail.com !!!!
