Fluid is leaking near U-joint?
There seems to be fluid leaking right where the drive shaft goes into the rear-end just behind the U-joint. Is there a seal that can be leaking? And is this complicated to fix? Sorry about the dumb question but just noticed this and makes me paranoid. Any help would be great! Thanks!
Originally Posted by TA TECH
Yeap pinion seal is leaking very common prob with the 7.5s Get ya a new seal put in and make sure the pinion gets 20 inch pounds of preload and it should solve it!
